September 29, 2021, 05:31 |
Pressure outlet
Rep Power: 4 |
In my simple case, I have a pipe with at the end 4 branches. I want to calculate the pressure drops in the system. I want to specify a mass flow inlet. Can I specify 4 outflow boundary conditions at the exits? Or should I use one pressure outlet at an exit (with zero pressure) and 3 outflow boundary conditions so that there is gauge pressure defined somewhere in the domain? If I dont have any pressure outlet defined it seems Fluent doesn't know the absolute pressure level anywhere? |
September 29, 2021, 16:46 |
Lucky
Rep Power: 66 |
It depends...
You shouldn't need an absolute pressure to even be able to use any outflow BCs in the first place. But if you are using a massflow inlet BC in a compressible problem where pressure matters, then you can use four pressure outlets with targeted mass flow rate option and no outflow BCs at all. |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 3, 2012 23:36 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
