Vacuum Pump Question
Old   February 26, 2016, 23:27
Default Vacuum Pump Question
slcousin is on a distinguished road
Hi All
I am trying to model a gas flow problem which can be broken down basically into a gas inlet into a chamber and a pipe leading out of the chamber to pump.
Having looked around I see that there is a neat way to model vacuum systems by treating it as a thermal problem where the various system components have clear conversions from a vacuum problem to a heat problem. This workaround is used predominantly for the UHV (ultra high vacuum) regime in which molecular collisions are dominating the system.
I am trying to model a system where flow is still dominating say 0.01bar to 10bar.
I'm trying to find out if there is a way to set the outlet boundary of the condition (the pump) to match the characteristics of the pump's i.e. a pressure dependent pumping capacity (see curve).
I've had convergence using an outlet vent and then setting a target mass flow to a fixed point taken from this curve, but I'd like to take the model to the next step and include the curve.
Any input is much appreciated!
Thanks in advance
slcousin is offline   Reply With Quote
Old   October 1, 2021, 05:19
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi, Have you found the solution?
Regards,
Sunil
sunilpatil is offline   Reply With Quote
radiation modeling in vacuum mirko OpenFOAM Programming & Development 7 May 20, 2016 08:31
Valveless Pump Boundary Load Convergence Problems in COMSOL v4.4 PKawun COMSOL 0 April 23, 2014 09:52
Micro pump design / Diaphragm pump Michael Main CFD Forum 2 March 1, 2013 01:56
pump as a momentum source PriA CFX 4 October 23, 2007 07:53
Discharge pump flow Ali Main CFD Forum 0 March 5, 2003 17:11
