October 19, 2021, 09:47 |
Coupled Wall
qntldoql
Rep Power: 5 |
Currently I am trying to simulate 3 domain problems. There are two layers of solids beneath an air channel. So the problem effectively becomes fluid (air) domain in contact with the primary solid domain, which is in contact with the secondary solid domain. Instead of creating the entire mesh as its own, I have created and imported the meshes for each domain. Then I used coupled-wall interface option to link (Primary_bottom) with (Secondary_top), etc. This creates Intf:01 - wall and its shadow. However, primary_bottom and secondary_top remains. (as non-overlapping walls) When I run the simulation, there is a heat transfer (flux) between the Intf:01-wall and its shadow. (for ex. 1101W for intf:01 and -1101W for its shadow) Therefore I believe it is working correctly. However, no flux is present between primary_bottom and secondary_top "Walls". In this case, does fluent "ignore" the presence of primary_bottom and secondary_top and only treat "intf:01" and its shadow in place? Additionally, when I tried to change boundary condition of the priamry_bottom and secondary_top walls to "via system coupling", it does not allow. It defaults to adiabatic wall. (However, I can observe the temperature difference for the secondary and primary domains, leading me to believe only the interfaces are treated as otherwise they both should remain at the same temperature.) I apologize for the long wall of text, but I wanted to confirm if what I believe is correct or not. Last edited by qntldoql; October 19, 2021 at 10:52. |
October 19, 2021, 12:32 |
Lucky
Rep Power: 65 |
Yeah that's the way it works. The boundaries of the original mesh adopt/inherit the properties of the interface. Basically, the stuff happening in the interface is used as BC's of the original disjoint meshes.
October 19, 2021, 12:53 |
qntldoql
Rep Power: 5 |
Thank you! I was worried as to if the original wall were somehow acting as a thin wall very near the interface, acting similar to a barrier.
Now I understand that interface condition is "transferred" to the original wall (after the name change to non-overlapping wall) instead of keeping the "adiabatic" condition of the non-overlapping wall. |
Interior vs. Coupled Wall between Different Solids | North Star | FLUENT | 2 | October 5, 2021 12:15 |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
Surface Heat Transfer Coefficient driven by a UDF, using coupled wall | ryanbezz11 | CFD Freelancers | 1 | March 16, 2018 03:01 |
Coupled wall for Interface/External Flow pass through internal flow | Onurozcan | FLUENT | 0 | December 16, 2015 14:15 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
