total heat transfer rate through wall and shadow not same
Like Tree1Likes
  • 1 Post By ares
Old   August 1, 2013, 02:08
Default total heat transfer rate through wall and shadow not same
preetam
preetam69 is on a distinguished road
hi,
in my simulation,the solution is converging really well.(i am solving a conjugate heat transfer problem)
but when i check the total heat transfer rate through the wall and the corresponding shadow wall,they are different(one almost half of the other).
shouldn't they be same? as both are actually same but one is shared by fluid and the other by the solid.(as far as my understanding)
can anyone point out what am i doing wrong over here?
thnx in advance.
preetam69 is offline   Reply With Quote
Old   August 5, 2013, 16:50
miyage
miyage218 is on a distinguished road
both of must be same. can you write values and assumption of simulation(about radiation - no radiation). maybe I can help you.
miyage218 is offline   Reply With Quote
Old   April 1, 2014, 07:39
Default Different Total Heat Transfer rate between wall and its shadow
acdc_cfd is on a distinguished road
I am simulating a domain with a distributed heat source.
I calculate the corrispondent power I am injecting and compare it with the results I get.
Since I find I had different results I compare heat transfer rate between each wall and its shadow seeing that:
.for walls (positive heat flux):
if I sum all the heat transfer rate of the overall volume surface I do not get the overall power I am expecting to inject
.for shadows (negative heat flux):
if I sum all the heat transfer rate I get (with minus) the same power I am expecting to inject
This made me lead to see that for two walls (its an axisymmetric problem, the domain is a rectangle) the fluxes of wall and shadow wall are different
Does anybody found a similar problem?
acdc_cfd is offline   Reply With Quote
Old   October 2, 2017, 07:00
ares is on a distinguished road
After 4 years, did anyone solve this issue? I am having the same problem. The main issue is with radiation. I am using DO radiation model and I have an internal solid mass(therefore 2 sided walls) in a combustion volume. Walls are opaque and their emissivity is 0.9. Unless my solid is semi-transparent and the solid zone participates in radiation, I always see different radiation heat transfer rates on different sides of the same wall.
Can anyone explain how this works please?
Thank you in advance,
Best regards,
Ind88 likes this.
ares is offline   Reply With Quote
Old   November 25, 2021, 02:59
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Hi all,
Again after 4 years
Anyone can clarify the situation? I posted to ansys forum and still waiting.
atelcikti1 is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 07:01
wall & wall shadow net heat flux Barbaros FLUENT 1 August 5, 2006 02:00
