December 5, 2021, 12:07 |
Customizing DPM sampling output
Mahdi
Rep Power: 9 |
Hi Everyone!
I am using the sampling option of particle tracking to record the location of the released particles in my solution domain. Since, the Fluent is writing all particle information at every time step, the file gets so huge and unreadable. Is it possible to set sampling in certain frequency like each 50 time steps? I am not familiar with UDF, but I found DEFINE_DPM_OUTPUT UDF in the documentation which is the default routine for this export. would you think I can change it? Any other suggestions about possible methods for exporting like to Ensight or CFDpost is appreciated as well. Thank you! |
dpm, sampling data, udf |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
ow to get DPM values as output for Design Xplorer | Darius12345 | Fluent UDF and Scheme Programming | 5 | December 17, 2020 11:48 |
Help: the output of DPM | zhaoxinyu | Fluent UDF and Scheme Programming | 6 | April 25, 2016 04:50 |
CGNS Output file parameters | ant0wn | SU2 | 1 | August 19, 2013 14:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
