NEW TUTORIAL: setting 2-node cluster with infiniband (WIN7) |
June 14, 2014, 14:32 |
#1 | |
Rick
Rep Power: 26 |
Hi all my friends,
in addition to the post I created here: http://www.cfd-online.com/Forums/flu...-machines.html I'm attaching a complete tutorial to setup a 2-nodes cluster with Infiniband. Download pdf file here: https://dl.dropboxusercontent.com/u/...INFINIBAND.pdf Quote:
Daniele |
August 12, 2014, 10:41 |
Rick
Rep Power: 26 |
SLES Tutorial can be found here:
http://www.cfd-online.com/Forums/flu...tml#post505595 |
December 12, 2014, 10:20 |
Quentin Lux
Rep Power: 14 |
Nice work, great tutorials.
September 14, 2015, 03:58 |
Anwar
Rep Power: 11 |
You can easily do it;
Firstly,what is the number of your cores i5 / i7 /2 You should know that increasing no0 of processors , decreases solution time but makes your machine heavy for doing other work. Follow picture steps then press,Ok |
February 17, 2016, 19:52 |
Hi ghost82,
I am trying to following your tutorial on windows 7. Would you share the infiniband driver used in your tutorial. I have the same infiniband adaptor. |
February 19, 2016, 10:27 |
Rick
Rep Power: 26 |
you need WinOF 2.1.2 no later version, otherwise drivers will not load. I cannot find them on mellanox website...you can download them from here (win7): ftp://ftp.supermicro.com/driver/Infi...2_win7_x64.msi
Google is your friend and the same for the search button! |
February 19, 2016, 12:25 |
Thanks for your help. I was able to repeat you work. The performance is very good. It's about 1.36 time faster than normal 1G Ethernet connection. |
April 26, 2017, 09:25 |
Rick
Rep Power: 26 |
Hello, updated links, after notifications by some users of expired links:
For windows 7: https://www.dropbox.com/s/dpab43kiuc...IBAND.pdf?dl=0 For SLES 11 sp2: https://www.dropbox.com/s/2owziokznp...11SP2.pdf?dl=0
November 30, 2017, 12:22 |
#9 | |
Rep Power: 14 |
April 9, 2018, 16:46 |
#10 | |
Rep Power: 8 |
What would you change in your tutorial for running on other OS like windows 10 or centOS ? Tahnks Mathieu |
December 12, 2021, 02:25 |
#11 | |
power
Rep Power: 4 |
Thanks a lot for this tutorial that will help lots of people. but I could not download the pdf file and I would be very thankful if anyone had time to send it to me using mail? my mail is "power.pwoer123@gmail.com" Also, I have a question about this tutorial. Does it work for further editions of windows and Ansys fluent; like windows 10 and Ansys 19.0? |
December 12, 2021, 02:27 |
#12 |
power
Rep Power: 4 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
Cluster OpenFOAM [Solved] | falcao | OpenFOAM Running, Solving & CFD | 24 | June 17, 2013 20:57 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
