Meshing Aerofoil Issues
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 13, 2021, 06:18
Question Meshing Aerofoil Issues
Adam
adamqb3 is on a distinguished road
Hi all
New user to fluent here and am trying to model a scenario of a wing with a Gurney flap attached to the trailing edge.
I have tried to split the surrounding c-mesh into quadrants and using sizings and a Bias to achieve a good mesh around the flap however the boundary layer is never well resolved (y plus <1 never met) and the flap mesh is always bad.
Instead I tried this new approach whereby I create a small oval face over the wing and apply a inflation layer between it and the structured mesh on the outside (see fig1). This seems to work but adds some mesh in the aerofoil section I froze and removed from the c section and oval surface see fig2 and 3.
Does anyone know why the mesh if forming in parts of the cut out geometry?
Are there any better ways to model this scenario?
Thanks!
adamqb3 is offline   Reply With Quote
Old   December 14, 2021, 00:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
try to avoid any sharp edges in model
most likely you want mesh to be conformal through the domain. to do that put all your zones into one part in design modeler
I recommend you to check few videos in youtube to get better understanding of you should finally make, put into sear line:
"ansys fluent airfoil meshing good practices"
adamqb3 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 14, 2021, 09:37
Adam
"most likely you want mesh to be conformal through the domain. to do that put all your zones into one part in design modeler!"
What do you mean by this sorry? Make sure to keep the whole wing and flap in one quadrant? do you have pic perhaps?
Thanks for the help
Issues with turbogrid meshing and mikandri CFX 7 September 13, 2020 16:10
Meshing issues with 2D model in CFX violethill CFX 3 June 29, 2016 10:46
[ANSYS Meshing] 3-d Aerofoil meshing moonser ANSYS Meshing & Geometry 2 March 9, 2012 02:04
[ICEM] Global Element Seed Size? Tetra meshing issues info_bahaider ANSYS Meshing & Geometry 0 November 28, 2011 09:12
Issues with dynamic meshing sridhu88 FLUENT 1 June 11, 2009 17:46
