Partition method "Metis" is not allowed warning in fluent
Like Tree1Likes
  • 1 Post By mehulkumar
Old   November 24, 2014, 13:38
Default Partition method "Metis" is not allowed warning in fluent
reza67 is on a distinguished road
hi everyones
after meshing my geometry when I open the file in fluent below warning is shownig to me
how can i solve it ?
Warning: Partition method "Metis" is not allowed for
autopartitioning for cases with nonconformal
interfaces before the interfaces are defined
and intersected, use "Principal Axes" instead.
You may use the "Metis" partition method
after the case is read in and the interfaces
are intersected.,
distributing mesh
parts...,
faces...,
nodes...,
cells...,
materials,
interface,
domains,
zones,
bonded_-_looleh_to_ab-trg
bonded_-_looleh_to_ab-src
bonded_-_khak_to_grout-trg
bonded_-_khak_to_grout-src
bonded_-_grout_to_looleh-trg
bonded_-_grout_to_looleh-src
tagharon-grout
tagharon-ab
tagharon-looleh
tagharon-khak
share_khak
outlet
inlet
grout
ab
looleh
khak
interior-grout
interior-ab
interior-looleh
interior-khak
wall-grout
wall-looleh
wall-khak
interior-13
wall-27
wall-28
interior-29
wall-30
wall-31
interior-32
wall-33
wall-34
mesh interfaces,
Note: Slitting sliding interface zone 32 into a coupled wall.
creating wall-32-shadow
parallel,
Done.
thanks
reza67 is offline   Reply With Quote
Old   November 29, 2014, 10:41
no one knows ?
Old   November 29, 2014, 13:06
mehulkumar is on a distinguished road
You need to create conformal mesh. To do so, create group of all parts in DesignModeler. And re-mesh. Most probably it will solve your problem.
reza67 likes this.
mehulkumar is offline   Reply With Quote
Old   December 1, 2014, 04:23
thanks mehulkumar
i split my geometry in 2 parts and mesh each one again and know this massage doesn't appear
Old   January 12, 2022, 09:26
Default Same problem
Omkar Mogare
Omkar Mogare is on a distinguished road
I am also encountering the same problem. I'm doing an analysis of 3D Darrieus VAWT. I have only two parts, ie rotating domain inner and stationary outer domain.
Omkar Mogare is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
OpenFOAM Solaris mamaly60 OpenFOAM Installation 13 May 10, 2010 21:16
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
