Urgent:error regarding save
Like Tree1Likes
  • 1 Post By sadnar
Old   March 23, 2020, 02:17
Default Urgent:error regarding save
chodvadiyaharsh is on a distinguished road
RESPECTED MEMBERS OF FORUM
SUB:error regarding save the model of ANSYS FLUENT
i have use the ANSYS 2019 R2 STUDENT VERSION.
i have model as per steps like 1)geometry then 2)messing then 3)setup
all task completely with zero error
but when i cancel all task and save from ANSYS WORKBENCH
FROM task bar-file>save>d drive(file name)
then model will save with appropriate name
but after that when i open this model there is shown error regarding save and model will be corrupted. solution will not open.
i have try so much but there is same error in all models .
please help me .....my project has sttoped because of this kind of error since 1 month
> Cannot change directory to D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\FluentWarning: Ignoring WB preference save-post-processing-images
Error: File "D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\Fluent\FFF-1.cas.gz" not found!
Error Object: #f
Error: cl-set-default-save-dir: path does not exist.
Error Object: "D:\DISSERTATION MODEL\RECESSION\0.5B\21-03-2020\RE-0.5-30?_files\dp0\FFF\Fluent"
chodvadiyaharsh is offline   Reply With Quote
Old   March 23, 2020, 04:15
Default Files
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
One thing you can do is to check for the existence of the files in your harddrive. If those files are there, then you don't need to worry. Open the project in WB, go to View > Files, and then right click on each file and select Repair.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   January 18, 2022, 14:45
Suat
sadnar is on a distinguished road
I had the same error. I realized that my folder path has Turkish character like "ş","ö" . So changed it and the error gone.
lvl99 likes this.
sadnar is offline   Reply With Quote
Very quick - Journal file command to save monitors lcaBR FLUENT 2 October 18, 2022 12:26
[General] Save Data for all time steps mvdl1996 ParaView 3 March 30, 2021 02:12
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
save case & data Saman95 FLUENT 1 August 12, 2018 06:09
[General] Save Animation Settings TomBot ParaView 2 August 26, 2017 07:54
