UDF-DROPLET EVAPORATION-interfacial area density |
January 19, 2022, 01:03 |
masoud fard
Rep Power: 4 |
Dear friends
The following udf has been used for calculation of interfacial area density, which is need for prediction of evaporation rate from a single droplet. The udf can not calculate the theta, Anybody know what is the problem? /**** Compute the interfacial area density ****/ NV_V(G,=,C_VOF_G(c,w_liq)); /* vof gradient vector assignment*/ theta = atan(G[0]/G[1]); /* compute angle of VOF gradient vector, n1/n2 because of how geometry is set up in Fluent */ cotan = cos(theta) / sin(theta); /* compute cotangent of angle*/ A = C_VOLUME(c,mixture_thread)/(2*pi); /* in 2D- axis area computed from volume */ len = sqrt((2*C_VOF(c,w_liq)*A/cotan) + (2*C_VOF(c,w_liq)*A*cotan)); /* compute length of interface in a cell */ ad = len/A; /* calculate interfacial area density*/ /***** Computed the area density ad = length of interface / area of cell ***/ |
January 19, 2022, 02:35 |
Alexander
Rep Power: 34 |
did you include math.h ?
best regards ****************************** press LIKE if this message was helpful |
January 19, 2022, 02:40 |
masoud fard
Rep Power: 4 |
January 19, 2022, 03:29 |
Alexander
Rep Power: 34 |
include math.h folder and recompile.
if you need help put here full code, compilation log, description of errors
February 21, 2022, 15:44 |
error in udf-excuted on demand-parallel mode
masoud fard
Rep Power: 4 |
Dear AlexanderZ
Following udf is working in serial processing option, but under parallel mode, the error "Node 999999: Process 13848: Received signal SIGSEGV. MPI Application rank 0 exited before MPI_Finalize() with status -1 The fl process could not be started" appear when "excuted on demand" is selected. please let me know your thought,,,, #include "udf.h" DEFINE_ON_DEMAND(on_demand_calc) { Domain *d; /* declare domain pointer since it is not passed as an argument to the DEFINE macro */ real R=8.314; real D=26.1e-6; float Y_W,X_W,Y_A; float T_cell, P_cell, P_sat,Powsat; Thread *t; cell_t c; d = Get_Domain(2); /* Get the domain using ANSYS Fluent utility */ /* Loop over all cell threads in the domain */ thread_loop_c(t,d) { /* Compute max, min, volume-averaged temperature */ Y_W = C_YI(c,t,0); Y_A = C_YI(c,t,1); X_W = (Y_W*29)/((29*Y_W) + (18*Y_A)); T_cell = C_T(c,t); /*cell mixture temperature*/ P_cell = C_P(c,t); Powsat=(8.07131-1730.63/(233.426+(T_cell-273.15))); P_sat = pow(10,Powsat)*133.322; /* Loop over all cells */ begin_c_loop(c,t) { C_UDSI(c,t,0) = C_VOF(c,t); C_UDSI(c,t,1) = C_YI(c,t,0); C_UDMI(c,t,1)=NV_MAG(C_UDSI_G(c,t,0)); C_UDMI(c,t,2)=NV_MAG(C_UDSI_G(c,t,1)); C_UDMI(c,t,4)= pow(C_VOLUME(c,t),-0.333)*4.83; if (C_UDMI(c,t,1)>40) { C_UDSI(c,t,1)=P_sat/ P_cell; C_UDMI(c,t,2)=NV_MAG(C_UDSI_G(c,t,1)); C_UDMI(c,t,0)=D*P_cell/(R*T_cell)* C_UDMI(c,t,2)*C_UDMI(c,t,4); C_UDMI(c,t,5)=ABS(D*P_cell/(R*T_cell)* C_UDMI(c,t,2)); } else {C_UDMI(c,t,0)=0;} } end_c_loop(c,t) } } DEFINE_MASS_TRANSFER(mass_transfer1, c, t, from_phase_index, from_species_index, to_phase_index, to_species_index) { float m_lg, T_cell, P_cell, P_sat,Powsat; float NV_VEC(G); float X_W, Y_W, Y_A; float cur_ts; Thread *w_liq, *gas_mix, *w_gas; face_t f; Domain *mix_domain, *pdomain; int i, pdomain_index; float area[ND_ND], A, ad, theta, cotan, len; /******** Define variables *********/ mix_domain = Get_Domain(1); /* pdomain = DOMAIN_SUB_DOMAIN(mixture_domain,2); */ /* For gas domain */ pdomain_index = 0; pdomain = DOMAIN_SUB_DOMAIN(mix_domain,pdomain_index); w_liq = THREAD_SUB_THREAD(t, from_phase_index); gas_mix = THREAD_SUB_THREAD(t, to_phase_index); w_gas = THREAD_SUB_THREAD(t, to_species_index); T_cell = C_T(c,t); /*cell mixture temperature*/ P_cell = C_P(c,t); /*cell mixture pressure*/ m_lg = ABS(C_UDMI(c,t,0)); C_UDMI(c,t,3)=m_lg; return (m_lg); /* return value of mass transfer rate */ } |
Density UDF | lehoanganh07 | Fluent UDF and Scheme Programming | 3 | August 17, 2014 09:36 |
Density UDF for supersonic flow | David Christopher | Fluent UDF and Scheme Programming | 0 | April 18, 2013 05:48 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
multiphase interfacial area density model | Paul | Main CFD Forum | 0 | August 5, 2003 17:33 |
density update by UDF in non-premixed combustion | IKSOO | FLUENT | 2 | December 8, 2002 20:37 |
