Display mesh on top of Pathlines from TUI Command Line
Old   January 19, 2022, 11:17
Default Display mesh on top of Pathlines from TUI Command Line
Chiara
Chiara1618 is on a distinguished road
Hi, I'm using Ansys Fluent and I'm trying to execute the post process directly from the command line.
In particular I'd like to to add specific part of the mesh to the plot of the path lines.
In order to draw pathlines I write the command: /display/object/display/pathlines-1
where I've already defined all the characteristic of the pathlines I want to draw. The problem is that the "Draw mesh" box deselects if I run the command from the TUI.
Any ideas to solve this problem and add the mesh during the display of the path lines?
Thank you for you help
Chiara1618 is offline   Reply With Quote
Old   January 20, 2022, 23:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may create a scene and put there both mesh and pathlines contours
display objects create scene
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 21, 2022, 08:41
Chiara
Great idea!!
Thank you so much Alexander
draw mesh, fluent, mesh, pathlines, tui
[blockMesh] Floating Point Exception while generating wedge based mesh jns-v OpenFOAM Meshing & Mesh Conversion 9 July 8, 2021 05:36
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 13:05
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 14:41
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
