Can we a create spatial-temporal velocity profile in Ansys Fluent?
Old   February 12, 2022, 00:27
Default Can we a create spatial-temporal velocity profile in Ansys Fluent?
Dnyanesh Mirikar
DnyanMiri is on a distinguished road
I am doing a 2D axisymmetric simulation of a pulsating jet impingement using ANSYS Fluent.
- The geometry/mesh is a rectangular domain, with an inlet at one corner
- In the case of the steady jet, I used to simulate a separate simulation for the same diameter pipe flow, and export velocity from there to the current domain
- But in the case of pulsating jets, the velocity varies with time and space at the domain inlet
- When I apply a time-varying sinusoidal velocity profile at the inlet, I get a spatially uniform velocity profile at the inlet
- One idea is to include the pipe length in the current geometry/mesh domain, but that will increase the computational time and cost when doing parametric investigation
- Is there any way to include a spatial and temporal variation in the velocity profile at the inlet without adding a whole pipe geometry to the mesh?
Please let me know if more information is required from my side. Thank you.
DnyanMiri is offline   Reply With Quote
Old   February 15, 2022, 01:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may control boundary conditions using transient profile or using udf (define_profile macro), now expressions are available also
it could be both spatial and temporal variations
for example: you've mentioned you've applied a time-varying sinusoidal velocity profile at the inlet -> add there coordinate dependence for velocity (across inlet)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
fluent, jet impingement, pulsating jet, udf, velocity profile
Create a new coordinate system in ANSYS FLUENT amind FLUENT 0 February 7, 2022 05:56
Ansys Fluent UDF, Wall Average Temperature Depend On Inlet Velocity ozgeozge Fluent UDF and Scheme Programming 1 April 15, 2019 01:31
How to create velocity profile for falling ball in fluent CFD post processing valr FLUENT 2 June 13, 2018 06:18
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
How to create non-uniform velocity profile in FLUENT? pankaj FLUENT 7 October 24, 2016 04:52
