How can I get data from Iso clips?
Old   February 24, 2022, 20:37
Default How can I get data from Iso clips?
NJ
arsjzy is on a distinguished road
Hi, I have some questions about the iso clips.
As the picture shows, the iso clip surface is a part of the sidewall and bottom wall.
In my design, I can get average heat flux on the sidewall and bottom wall by using 'areaAve(Heat Flux)@surface'. But it always shows 'undefined' when I want to get average heat flux on the iso clip surface in the same way 'areaAve(Heat Flux)@Iso Clip'.
Any difference for the ios clips surface?
arsjzy is offline   Reply With Quote
Old   September 19, 2023, 05:50
SUBHAM
subhcfd is on a distinguished road
Have you found a solution to this problem? I am also facing the exactly same issue
subhcfd is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 05:33
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
