Strange observation in torque values for a Wind Turbine
Old   February 28, 2022, 03:56
Default Strange observation in torque values for a Wind Turbine
Pranjal Anand
Pranjal193 is on a distinguished road
I am simulating a HAWT (horizontal axis wind turbine) , specifically NREL Phase VI blade with a slot to help in passive boundary layyer control . I am simulating just one blade with a moving reference frame as was used in my primary article of reference. As I keep adapting mesh count based on y+ values the torque value (obtained from moments menu in reports) keeps going down, and significantly, moving further from the desired value. It was ~ 120 Nm at the count of 1.5M cells, and when increased to 9.2 M, it was 90 Nm. I dont understand how refining the mesh can lead to less accurate results.
I am using a tet mesh with no inflation layers as ANSYS meshing was creating bad quality elements when I tried to. I am using the SST k-omega model, and by refining the mesh I expect to get more accurate results. Is the lack of an inflation layer the problem here? Or, is it the slotted geometry(which might need a very refined mesh?)?
Considering that I do not have ICEM CFD, is there a way to make a better mesh if that is the problem?
Pranjal193 is offline   Reply With Quote
Old   February 28, 2022, 05:22
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
i can hardly imagine you are able to control y+ value without inflation layer.
you may use mesh without inflation layer in case you are using wall treatment functions
on the other hand as you are focused on boundary layer simulation it sounds essential to have good mesh in that region.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
mesh adaption, wind turbine blade
wind turbine doesn't converge arashn18 CFX 15 June 8, 2017 06:18
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 03:35
Wind turbine simulation problem sanchovg2 STAR-CCM+ 12 March 5, 2013 04:18
how to find wind turbine torque from CFD ? siripon Main CFD Forum 1 August 27, 2012 00:41
