March 1, 2022, 07:18 |
Fluid material giving error in materials
Hi
Hi all,
I am performing a supersonic simulation where the fluid medium is N2 (nitrogen) gas rather than air. I have changed the materials to nitrogen under the materials section; however, it just adds to the nitrogen and does not delete air. In addition to this I can not also delete air since it says that it is "still in use by created_material_7". This material is an interior part of the BC (boundary condition). The warning that pops up is, " Pressure far-field boundary condition can only be used with ideal gas law. Please change either the boundary condition type or enable ideal gas law. Solver cannot proceed until this is fixed." This shows that it is taking air as a medium instead of nitrogen, and I don't want that to happen. I would really appreciate if anyone can kindly assist me in this matter. Thank you very much. |
air, nitrogen flow, supersonic flow, transonic flow, unstructured mesh |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
