2D-LES simulation heat of reaction source much higher estimated
Old   April 6, 2022, 13:04
Question 2D-LES simulation heat of reaction source much higher estimated
Ash Kotwal
Ash Kot is on a distinguished road
Hello Everyone,
The 2D LES simulation of combustion estimate heat of reaction source as 9.145e+9, while monitors of temperature, species, continuity, and residuals show no change. The attach files are images of flux reports of mass and energy balances.
Information about the models:
  1. Combustion model
    Main: Species Transport, Reactions
    Reactions: Volumetric
    kinetics Solver: CHEMKIN-CFD solver
    Turbulence-Chemistry Interactions: Eddy-Dissipation Concept
    Remaining options are default
  2. Turbulence model
    main: Large Eddy Simulation
    Subgrid model: Smagorinsky-Lilly
    LES Model options: Dynamic Stress, Dynamic Energy Flux
In the attached files, monitors of temperature, pressure, and one of the species (_{}NO_x) does not show any variation and are at consistent values
Here Temperature monitor at outlet show variation however peak and bottom of curve holds difference of only 10°K to 15°K.
(_{}NO_x) species monitor show constant value of 0.00040089, which is desired.
Pressure monitor at outlet does not show any variation at outlet
However the energy and mass balance is far off that expected and make no sense.
Higher order schemes are employed in simulation, but still it is failing to achieve net mass and energy balance at value less than 1% of added heat of reaction.
Perticularly, the heat of reaction source makes no sense and it is obscurely higher than expected. Due to mass and energy imbalances the simulation is yet to converged, while the monitors does not change with any time-step whatsoever.
Does any one face this type of problem while simulation of LES model in 2D domain in co-ordination with Species Transport, Reactions model?
File Type: jpg Solution Methods for equations in model.JPG (47.8 KB, 0 views)
Ash Kot is offline   Reply With Quote
2d; les; no conservation
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
