April 19, 2022, 12:34 |
Optimal Solver Settings
Ethan Whiting
Rep Power: 4 |
Im trying to simulate the flow through a S-Duct intake with an inlet Mach of 0.8 and a Re of approx 1.4x106.
I created the mesh ensuring that skewness < 0.8, max included angle is approx 145 and that the boundary layer cells are created from a structured mesh to maintain wall orthogonality. The initial cell spacing in the boundary layer is approx 1x10-6 which gives a y+ of less than 1. From what I have read online these should all be fine for Fluent. For the first part of the simulation I use inviscid flow and first order for all discretizations. URFs are set to default. I have also tried this with constant density and without constant density. However, the simulation diverges after about 35 iterations. Is there any additional settings I could try that will help the solution to converge? |
laplacianFoam - solver settings for steady state diffusion problems | Adam_K | OpenFOAM Running, Solving & CFD | 5 | June 8, 2021 14:33 |
Details Fluent Solver Settings for Marine Propeller Performance | Hayatul_Maruf | FLUENT | 3 | July 5, 2018 14:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
solver settings, residuals plateau for a long time | Mumawalde | CFX | 2 | December 17, 2007 08:49 |
