Reversed flow and turbulent viscosity
Old   May 10, 2022, 08:15
Default Reversed flow and turbulent viscosity
Bhavesh
BHAVESHNAGAR98 is on a distinguished road
Hi Fellow members,
I am trying to simulate leakage of H2 gas from a nozzle in a garage with vent outlet and pressure outlet(door), I have a high turbulent flow(Re = 108000) releasing from nozzle and using sst k omega model for that. Problem is I am having reversed flow at my pressure outlet (covering ~60-70 % area), also I am getting warning "turbulant viscosity limited to 10^5 in x cells" . I tried reducing mesh sizing (also making it finer at appropriate location), reducing URFs, moving the outlet further downstream, changing boundary conditions, reducing the timestep, changing the discretization methods to first order. But the problems persists, I am out if ideas.
kindly help me if any with my problem.
NOTE: I have attached a pdf containing my geometry, mesh and solution approach.
link: https://drive.google.com/file/d/1Jpe...ew?usp=sharing
BHAVESHNAGAR98 is offline   Reply With Quote
Old   May 10, 2022, 09:14
Vestdam
Vestdam is on a distinguished road
The warnings that you get are just warnings. Reversed flow on the outlet might be expected from the massflow from the nozzle and massflow through the outlet vent? You should probably monitor the massflows on the inlet and outlets.
I have not done this type of simulation before, but my guess would be that the divergence is due to the gas velocity of 1300 m/s and a timestep of 0.005 s, which I assume would give you a very high Courant number? A Courant number of 1 would require cell lengths of 6.5 meters.
Again, I have not done this before, but you might need to rethink how you define your nozzle inlet conditions.
Vestdam is offline   Reply With Quote
Old   May 10, 2022, 14:20
Bhavesh
Yes, I think because I have given higher mass flow rate at outlet vent than inlet flow rate, that's what causing flow reversal. thanks for pointing that out. I also reduced time step size to 1e-6 so turbulent viscosity warning is gone.
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Submerged intake: Reverse flow in inlet outlet, turbulent viscosity limited CFDblast FLUENT 0 September 13, 2019 07:08
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
