Finite-Rate/Eddy-Dissipation doesn't work!
Like Tree7Likes
Old   December 31, 2009, 19:09
Default Finite-Rate/Eddy-Dissipation doesn't work!
jiahang
jiahang is on a distinguished road
Hi there:
I am setting up a very simple case: injecting CO into air to achieve the combustion. The carbon monoxide air is my mixture. First I chose Finite-Rate/Eddy-Dissipation as my combustion model, there is no combustion at all even after I initialized my case with 2000K!
Later I only use Eddy Dissipation model, then the combustion comes.
Does someone know why I can't use the first model? I find other people did similar thing with this model, so I assume that should work for me too.
Thank you for your any suggestion so much! Happy new year to you!
maziar77 likes this.
jiahang is offline   Reply With Quote
Old   December 31, 2009, 22:06
Default you may try initialize----patch give a high temperature
gsyuan
gsyuan is on a distinguished road
gsyuan is offline   Reply With Quote
Old   January 1, 2010, 18:20
Default Thank you gsyuan!
jiahang
Hi gsyuan:
Thank you for answering my question. I did initialization already with 2000K, but nothing changes.
My kinetic/ED model's set up of BC conditions is exactly as the same as the ones of ED model. Since I can see the combustion in ED model, I think I may make a very basic mistake somewhere. I don't know if the former model has different requirements on the case?
I hope I explain my problem well to you.
Thank you again and wish you a good new year!
jiahang
Old   July 25, 2012, 04:59
Prakash Ghose
pghoseju is on a distinguished road
The same problem I am facing too. Only with ED model it is working but FR/ED it does not work. Help me.......
pghoseju is offline   Reply With Quote
Old   July 25, 2012, 18:38
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
Is your simulation transient? I'm having the same trouble with my transient simulation.
NormalVector is offline   Reply With Quote
Old   July 25, 2012, 22:59
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
Ansys Fluent have enabled spark model for ignitions. Try them. Ooh, I forgot something, you should also patch a very small amount of species (reactants and products) around the spark point to could start ignition.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   July 26, 2012, 06:49
Prakash Ghose
thank you for your suggestion. I am using steady flow. I have given pach 1500 K near ahead the nozzle tip. and I have tried with paching to the whole body at temp. 1500k. I pached the products only on the whole domain.
Now my problem is that when I am running with FR/ED, it is running and I checked the results (temp, species mass fraction etc.) after few iteration(50 iteration) , It shows the results. but when I left it for more iteration(600 iteration), the resulted temperature is now the cold flow temperature.
some time it shows the flame (maximum temp.)at the combustor exit. which is not right. actually what may be the problem?
Old   August 2, 2012, 07:45
Prakash Ghose
No my problem is steady one. Now my problem is solved. It is working now. But problem is that, it shows the maximum
Old   August 8, 2012, 03:48
Prakash Ghose
Originally Posted by jiahang View Post
Hi there:
I can help you. but first of all you have to say.
1. whether you are using spray combustion or simple gas combustion?
Old   March 11, 2013, 12:54
Jenny
Jenny_W is on a distinguished road
I am modelling compressible non-combustion reacting flow in FLUENT. I am using the species transport laminar finite rate model but there is no reaction.
I have initialized and patched a region of high temperature and high reactant concentration near the inlet. I also tried increasing the inlet temperature but nothing works. I still have no reaction.
If anyone can know what may have gone wrong, please give me some suggestion.
Thank you,
Jenny
Jenny_W is offline   Reply With Quote
Old   March 12, 2013, 00:42
SSL
msaeedsadeghi is on a distinguished road
Originally Posted by Jenny_W View Post
Thank you,
Jenny
I always patch both reactants and products in whole domain but in a small amount. Also patch reasonable temperature on a proper location.
Jenny_W and Tleja like this.
msaeedsadeghi is offline   Reply With Quote
Old   March 12, 2013, 03:46
Jenny
Hi Saeed,
I will do that. Thank you very much for your help.
Regards,
Jenny
Old   March 13, 2013, 15:08
Jenny
Hi Saeed,
I have tried patching the whole domain with reactions, products and patch a region with high temperature and it's still not working. Would you please suggest what else I could try?
Thank you,
Jenny
Old   March 15, 2013, 08:39
Prakash Ghose
Hello Jenny.
1. what is your fuel?
2. whether it is liquid fuel spray combustion or gaseous fuel combustion?
Any way you can use an option "relax to chemical equlibrium".
where you have to use ''chemistry calculation per iteration is =10''
''aggressive factor =0.5''
Remeber
In ISAT table you have to select the fuel.
and before running you have to clear the Isat table.
after paching you will run the programme for let say 300 itr.
again patch the computational domain like early case.
again run it without initialize it.
then see what happen.............
Old   March 15, 2013, 08:40
Prakash Ghose
But at last I will suggest you to non-premixed model, if your problem is non premixed
Old   March 15, 2013, 10:25
Jenny
Hi Prakash,
Thank you very much for your suggestions. I will try to do as you recommend.
1. I do not use fuel. I am modelling non-combusting atmospheric chemical reaction. Since my reaction is not available in FLUENT, I have to import the reaction in CHEMKIN format into fluent.
2.The is gaseous reaction.
3. I tried using non-premixed combustion model with steady flamelet chemistry. After importing CHEMKIN mechanism and thermodynamic database files, I failed to calculate flamelets.
FLUENT exit and reported the error "Single flamelet extinguished Try again with lower Scalar Dissipation". I tried lowering the scalar dissipation but it didn't work. When I tried activating "Liquid Micro-mixing", the error was gone but i think that this option is not appropriate for my case as it is a gaseous reaction.
Can non-premixed combustion model be used to simulate non-combusting gaseous chemical reaction?
Thank you,
Jenny
Old   April 16, 2014, 11:51
WJXu is on a distinguished road
Hi, I am facing the same problem now. I am simulating the gas combustion, CH4/Air from different inlets. ED model reacts, while FR/ED doesn't. How did you resolve your problem? Endless thanks, please help me.
WJXu is offline   Reply With Quote
Old   April 13, 2015, 04:40
hazwani
hazwani fatihah is on a distinguished road
Hi guys,
My simulation was transient. I used species transport laminar finite rate model for methane/air combustion. I got very high velocity, it was wrong. Am I picking the right model? Should I used FR/ED for my model?
Id appreciate if anybody could help me out on this.
Thank you
hazwani fatihah is offline   Reply With Quote
Old   April 24, 2015, 22:28
sanjeet Limbu
sanjeetlimbu is on a distinguished road
Dear Sir
I am trying to do autoignition for mixture heptane/N2/O2/AR: 0.562/58/30/10 mole fraction ratio
But unable to do it by any method .. I set the initial T=766K and Presuree= 14.1 bar
1. I tried the laminar rate- it showing error : flat Temp profile
Please guide me how to get autoignition by laminar ... I am in trouble
sanjeetlimbu is offline   Reply With Quote
Old   April 25, 2015, 01:13
sanjeet Limbu
After trying in step to off volumetric calculation and run again with the all equations set.
I am getting error after some iteration as
finite volume VS finite element solomon FLUENT 4 April 3, 2015 00:10
Star ccm 9.02 - unsteady flux dissipation correction fivos STAR-CCM+ 4 April 28, 2014 09:37
Control Volume , Finite Volume, Finite Control Volume, Finite Element Method technocrat.prakash Main CFD Forum 1 April 24, 2010 19:24
Finite volumes vs. finite elements: applications Lionel S. Main CFD Forum 10 January 22, 2007 10:51
Finite Volume midplane algorithms Ricardo Bonon Main CFD Forum 0 May 17, 2000 17:03
