Urgent_ Flow through porous medium in PEM water electrolyser
Old   July 11, 2022, 07:41
Default Urgent_ Flow through porous medium in PEM water electrolyser
Ashwin
Ashwin_francis is on a distinguished road
I am simulating a two phase flow in a porous medium inside a Electrolyzer and i am facing convergence issue while using Eulerian model with capillary pressure and Permeability as the considered parameters. Could someone help me to find a solution for it.
Primary phase: water
secondary phase: air
Steady state laminar flow
Wetting phase : water
non-wetting phase: air
contact angle: 20 degree
Cell zone: given inertial resistance, viscous resistance, capillary pressure, permeability, relative viscosity
BC: inlet water mass flow rate 1.5 kg/s
inlet air_ mass flow rate 0.0128 kg/s
outlet gauge pressure 0 bar
Ashwin_francis is offline   Reply With Quote
fluent, fluent - udf
porous medium thermal analysis with two fluid flow ymd FLUENT 0 October 21, 2021 14:49
Segmentation Fault Error due to the zero flow in porous jump boundary zypresse FLUENT 0 December 8, 2018 14:13
Porous Medium Flow Simulation SolidWorks rishabm FloEFD, FloWorks & FloTHERM 1 January 8, 2018 05:27
multiphase cylindrical flow through porous medium; BC adrianabm OpenFOAM Running, Solving & CFD 1 September 7, 2015 10:37
Turbulent flow through porous medium? Shankar FLUENT 3 September 26, 2002 15:46
