Do I Need to Return the Sliding Mesh Preview to the Original Position
Like Tree1Likes
  • 1 Post By Indra
Old   July 12, 2022, 11:12
Default Do I Need to Return the Sliding Mesh Preview to the Original Position
Nate Werner
nwerner1 is on a distinguished road
I am applying a sliding mesh that contains a rotating wing inside of a larger stationary zone. Here is a top view of the geometry from the ANSYS meshing tool showing the original position. Hopefully, the image has been uploaded.
In ANSYS FLUENT, when I preview the mesh it obviously moves the sliding mesh to a new position. Do I need to return it to the original position before running the calculation? And if so, how do I do that?
Thank you
nwerner1 is offline   Reply With Quote
Old   July 12, 2022, 11:40
Void_CFD-user
Indra is on a distinguished road
Thank you
You can' really restore the position of mesh once it's been moved. Always remeber to save before you preview or runn the simulation, then you can reload to initial state.
nwerner1 likes this.
Indra is offline   Reply With Quote
Old   July 12, 2022, 11:42
Nate Werner
OK, that is unfortunate. I will keep that in mind for the future.
preview mesh motion, sliding mesh
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
No matching function error: Phase change source term added to interMixingFoam wavefunction OpenFOAM Programming & Development 2 February 4, 2022 07:46
Sliding Mesh Problem cturutoglu FLUENT 12 September 2, 2016 08:58
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Sliding Mesh Sridhar FLUENT 0 August 23, 2002 14:54
