July 14, 2022, 02:16 |
Fluent meshing
tara behmanesh
Rep Power: 3 |
Hello
I'm new with ansys and CFD. And i'm trying to do a flow simulation with fluent+fluent meshing. Question1: I want to know is there anyway to know/calculate how to choose meshing parameters (like facesize, body-size values or something like smooth transition and number of boundary layers etc.)for a specific geometry? More detailed description: For example My geometry is a direct perfusion bioreactor which the scaffold(a porous zone) is embedded in it.(attached picture) In this case The porous zone is where the greatest gradient occurs and the most important area in this simulation.So i decided to do a face mesh on whole faces + a body mesh on the porous zone but i don't know what will be the proper size (target mesh size).so i just picked 1 for face-size and 0.0005 for the porous body. As you can see there is no logic and knowledge behind my choices . So i will be really really grateful if someone explain this or introduce a good source (video, tutorial, book,...) to learn. Link of the picture of my geometry (front cross section) : Question 2: Is there anyway to know that what is the optimum/maximum cell numbers in a mesh inorder to avoid system (loptop) crash? Software information: Ansys fluent with meshing 2021 R2 Hardware information: Intel core i7 (4th), 8 Thanks in advance |
July 15, 2022, 02:55 |
Alexander
Rep Power: 34 |
To make a suitable mesh you want probaly know characteristic size of phenomena you are tryuing to simulate.
so the mesh size should be small enough to represent these phenomena. Models are you going to use plays significant role either, for example heat transfer from fluid to wall: 1. In case you want to accurately get boundary layer -> usually you want refine mesh alot near the wall to have several finite volume per thickness of boundary layer 2. On the other hand you may use one wall treatment model -> in that case finite volume could be bigger that the thickness of boundary layer Optimal mesh is a mesh small enough to represent your model with a certain accuracy (which is defined by you) Max number of finite volumes depends on avaliable RAM and time you have to spend on computation.
best regards ****************************** press LIKE if this message was helpful |
July 21, 2022, 18:42 |
Experiences are matter
#3 | |
Arash
Rep Power: 3 |
In addition to dear Alexander's answer, It depends on the essence of the phenomena for example simulating an ignition in a combustion chamber is different from a simple flow over a plate, So you have to rich to these orders with experience in your related field. All the best, Arash |
mesh and fluent, meshing ; solver settings, meshing advice, meshing and geometry, meshing basics |
[Fluent Meshing] Rotating a mesh generated with Fluent Meshing | tinucci | FLUENT | 2 | April 16, 2024 10:23 |
[ANSYS Meshing] Defining a cell zone in ANSYS meshing for fluent | Stephen Waite | ANSYS Meshing & Geometry | 1 | July 4, 2022 09:21 |
Questions regarding meshing and postprocessing in fluent | DL598 | FLUENT | 8 | April 21, 2020 12:11 |
Transfer named selections from SW to Fluent Meshing | the-sted | FLUENT | 0 | May 1, 2016 23:44 |
Toolbars of Graphic windows in Fluent Meshing | Sina.Li | FLUENT | 1 | December 28, 2015 01:09 |
