Ansys Fluent crashing when starting simulation
Old   July 26, 2022, 12:40
Default Ansys Fluent crashing when starting simulation
Marc
marccfd25 is on a distinguished road
I've been trying to simulate the flow over a motorbike using Ansys Workbench Fluid Flow (Fluent).
I can prepare the geometry with symmetry without any problem and do a proper mesh with tetrahedrons and two bodies of influence and the inflation layers. This results in a mesh with 2939097 nodes and 11427731 elements. Also I have a medium skewness of 0,23322 and a medium orthogonal quality 0,75799.
However, once I have all the parameters set up and I start the simulation, before getting the first iteration it crashes.
May it be because my computer can't handle that many elements?
Or is it something else?
Thanks
marccfd25 is offline   Reply With Quote
Old   July 27, 2022, 00:14
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in fluent GUI go to tab general in the tree
press Check -> in must give you following at the end of report
Checking mesh..........................
Done.
Then press report quality button
if everything ok here, check your boundary conditions
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 27, 2022, 08:52
Marc
Done.
Okey, I've checked that and I don't get that message but this one:
Domain Extents:
x-coordinate: min (m) = -7.554571e-07, max (m) = 1.500000e+00
y-coordinate: min (m) = -2.061473e+00, max (m) = 6.438527e+00
z-coordinate: min (m) = 1.354801e-02, max (m) = 2.708548e+00
Volume statistics:
WARNING: 99 cells with non-positive volume detected.
minimum volume (m3): -3.691551e-08
maximum volume (m3): 1.813790e-03
total volume (m3): 3.430099e+01
Face area statistics:
minimum face area (m2): 1.484660e-09
maximum face area (m2): 3.435458e-02
WARNING: left-handed faces detected on zone 1: 6121509 right-handed, 187 left-handed.
WARNING: left-handed faces detected on zone 12: 64722 right-handed, 27 left-handed.
Info: Used modified centroid in 12 cell(s) to prevent left-handed faces............................
Done.
WARNING: Mesh check failed.
WARNING: left-handed faces detected on zone 1: 5866175 right-handed, 67 left-handed.
WARNING: left-handed faces detected on zone 12: 73 right-handed, 14 left-handed.
WARNING: left-handed faces detected on zone 1: 6070774 right-handed, 34 left-handed.
To get more detailed information about the mesh check failure
increase the mesh check verbosity via the TUI command
/mesh/check-verbosity.
Fluent can also try to fix the mesh check problems via the TUI command
/mesh/repair-improve/repair.
What can I do?
Thanks
Old   July 27, 2022, 09:02
Void_CFD-user
Indra is on a distinguished road
What can I do?
Thanks
Type the command as the message says to see if the mesh can be repaired. Once the repair is done, check the mesh again.
Or start the meshing from scratch, produce better mesh by following the criteria guidlines for mesh quality.
Indra is offline   Reply With Quote
error, fluent, workbench
Journal bearing simulation using ANSYS FLUENT zuraidah rasep FLUENT 3 June 2, 2021 08:39
Moving Shock tube simulation in Ansys fluent Patelp1996 FLUENT 1 September 11, 2020 04:16
Sudden decrease of simulation speed in ANSYS Fluent as the case runs haiteng FLUENT 1 July 15, 2020 08:37
TIG Welding simulation in ANSYS Fluent cfd335 FLUENT 1 August 30, 2018 12:17
Question about starting the simulation automatically one after another by Fluent Anna Tian FLUENT 1 January 23, 2014 19:23
