Activating gas radiation leads to energy imbalance
Old   July 8, 2019, 11:34
Default Activating gas radiation leads to energy imbalance
seph is on a distinguished road
Hi folks!
I am currently doing the official ANSYS tutorial with the can combustor (see picture, I think it's available in Fluent 2019 R1 only, Chapter 14), however with radiation included. I am using the k-epsilon standard, eddy dissipation for species transport and P1 model for radiation. When I keep the Absorption Coefficient of the mixture (methane-air) at 0 and check the Flux Reports of the (converged) solution, there is almost no energy imbalance in all three heat flux reports (Net result = 0-1 W).
However, when I change the Absorption Coefficient of the mixture to a non-zero value (either putting a constant or using the WSGGM), there is always an energy imbalance for the Radiation Heat Transfer Rate Flux Report, the other flux reports, however, are again 0-1 W (Mass Flow Rate is also at -1e-9). The residuals look pretty good and converged (Continuity at 1e-4, Energy at 1e-6, P1 below 1e-08, Species between 1e-4 and 1e-6, staying at constant level). I decided to observe the net radiation heat transfer rate during simulation and it also seems to converge but it stays at level that is way too high with a few thousands Watt (see pictures)). The mass-averaged temperature of the domain is also stable and does not change anymore. Same goes for the incident radiation for the walls.
The under-relaxation factors are all set to default. I am using the coupled scheme with pretty much everything second order (except Gradient). Steady. No pseudo transient. I've tried other cases including a simple cylinder and seeing always the same phenomenon: Absorption Coefficient set to zero works fine, but non-zero cases always lead to an energy imbalance for the Radiation Heat Transfer Rate.
You can find the boundary conditions below. Everything's the same as in the tutorial except for the wall whose temperature is set to 1300K (max material temperature, may not be a proper BC in this case but that's a different story) and the inner emissivity factor to 0.85. The walls of the swirl vanes are assumed to be adiabatic but they're rather small compared to the rest. The temperature contour (see picture) looks fine and pretty much the same as in the case of no radiation at all.
Hence the question is: why is there an energy imbalance in the Radiation Heat Transfer Rate flux report?
Boundary Conditions
Zones
name id type
outlet 10 pressure-outlet
inletair2 9 velocity-inlet
inletair1 8 velocity-inlet
fuelinlet 7 velocity-inlet
wallvanes 3 wall
wall-part-fluid 1 wall
wallvanes-shadow 6 wall
Setup Conditions
outlet
Condition Value
Backflow (((constant . 0) (profile )) ((constant . 0) (profile )) ((constant . 0) (profile )) ((constant . 0) (profile )))
Average Pressure Specification? yes
inletair2
Condition Value
Velocity Magnitude (m/s) 6
(((constant . 0) (profile )) ((constant . 0.23) (profile )) ((constant . 0) (profile )) ((constant . 0) (profile )))
inletair1
Condition Value
Velocity Magnitude (m/s) 10
fuelinlet
Condition Value
Velocity Magnitude (m/s) 40
(((constant . 1) (profile )) ((constant . 0) (profile )) ((constant . 0) (profile )) ((constant . 0) (profile )))
wallvanes
Condition Value
Thermal BC Type 1
Wall Motion 0
Shear Boundary Condition 0
Species Boundary Conditions (0 0 0 0)
wall-part-fluid
Condition Value
Wall Thickness (m) 0.005
Thermal BC Type 0
Temperature (k) 1300
Wall Motion 0
Internal Emissivity 0.85
wallvanes-shadow
Condition Value
Thermal BC Type 1
Wall Motion 0
seph is offline   Reply With Quote
Old   August 2, 2022, 12:33
E Vega
e_vega is on a distinguished road
Hi Seph
is maybe a while, but did you get any information on that?
I am having a similar problem when using a DO model in a mesh that uses symmetry and has steam as participating media. The energy balance is totally wrong when using radiation..
e_vega is offline   Reply With Quote
Energy imbalance seojaho CFX 6 June 21, 2016 20:35
terrible imbalance of energy equation for a rotating periodic domain liz CFX 6 December 1, 2014 22:09
Heat energy imbalance Coriolius CFX 4 November 5, 2004 22:29
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
