Import Viscous drag from Fluent to Static Structural |
August 27, 2022, 15:23 |
Karan Jha
I am using Ansys FSI simulation between an object in fluid flow with one-way coupling. When I try to import the forces, I can only import the pressure distribution from Fluent to Static Structural in Ansys. I wanted to know if there is a way to import the Viscous forces, or is it that the pressure forces that I import somehow account for the viscous forces as well. Thank You |
drag analysis, fsi, viscous forces |
Ishii-Zuber drag in Fluent | CeesH | Fluent UDF and Scheme Programming | 7 | March 16, 2017 09:52 |
pressure viscous drag on pipe | Hossam Alaa | FLUENT | 0 | December 30, 2014 13:50 |
FSI Fluent -> static structural | zytra | ANSYS | 4 | October 16, 2014 17:01 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
