February 25, 2014, 09:17 |
Valve seat warning problem
Michael Hilton
Rep Power: 12 |
I have designed a geometry of a piston cylinder with valves. However, when using the Ansys ICE package, when i select the valve seat in the input manager and click generate i keep getting the same error "select valve seat for the valve". Is anyone aware of this warning and how to solve it as I have been stuck on the solution for quite some time. I have attached jpeg files showing the error message and the valve seat i chose. Thank you |
September 2, 2022, 04:06 |
rahma
please i need how to solve this is problem about the valve seat
ansys 14.5, icem 3d, piston, valve simulation |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
OF14 compilation error bistreamb is already declared in this scope | rafal | OpenFOAM Installation | 5 | August 26, 2008 11:23 |
Add icoLagrangianFoam to FoamX | dyxu | OpenFOAM Running, Solving & CFD | 10 | June 11, 2008 09:53 |
