September 13, 2022, 12:11 |
SLURM issue
Arindam Singha
Rep Power: 12 |
Hi
I am trying to configure Slum in a Ubuntu Cluster. After installing Slurm and configuring, when I try to run script below, I get an error. #!/bin/bash # Command line args: case cells iterations # The name of the script is myjob #SBATCH --export=ALL #SBATCH -J fluent #SBATCH --partition=normal #SBATCH --account=xrg #SBATCH --time=01:00:00 # Number of nodes #SBATCH -N 1 # Number of MPI processes per node #SBATCH --ntasks-per-node=4 # The Journal file JOURNALFILE=test.journal # Total number of Processors # NPROCS=4 NTASKS=`echo $SLURM_TASKS_PER_NODE | cut -c1-2` NPROCS=`expr $SLURM_NNODES \* $NTASKS` fluent 3ddp -g -slurm -t4 -mpi=intel -path/opt/ansys_lic/v222/fluent -ssh -i $JOURNALFILE > fluent-out.log This is the error I receive. /opt/ansys_inc/v222/fluent/fluent22.2.0/cortex/lnamd64/cortex.22.2.0: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory I am able to launch fluent normally with and without GUI if I use X2Go or Putty. So, fluent is installed currently. Right now, I am running fluent using non graphics option from fluent, but wanted to have the Slurm working for productivity. Did anyone know how to resolve this error? Thanks Arindam |
September 13, 2022, 12:22 |
Brandon
Rep Power: 7 |
I think the fix is quite simple. I have had the issue with another software, not fluent. But when you are missing a library file you simply need to add a PATH field to your bash file.
You probably have it set-up on your bashrc file but when you run with slurm you are not using your own user account anymore so the bashrc is not recognised. This is how it is for me, at least, on the cluster I use. |
September 13, 2022, 15:00 |
Arindam Singha
Rep Power: 12 |
Thanks for your help. I have located that library in /usr/lib/x86_64-linux-gnu.
dpkg -L libgl1 /. /usr /usr/lib /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/libGL.so.1.7.0 /usr/share /usr/share/bug /usr/share/bug/libgl1 /usr/share/bug/libgl1/control /usr/share/doc /usr/share/doc/libgl1 /usr/share/doc/libgl1/copyright /usr/lib/x86_64-linux-gnu/libGL.so.1 /usr/share/doc/libgl1/changelog.Debian.gz and then modified my script #!/bin/bash # Command line args: case cells iterations # The name of the script is myjob #SBATCH --export=ALL #SBATCH -J fluent #SBATCH --partition=normal #SBATCH --account=xrg #SBATCH --time=01:00:00 # Number of nodes #SBATCH -N 1 # Number of MPI processes per node #SBATCH --ntasks-per-node=4 export FLUENT_GUI=off FLUENT_ARCH=lnamd64 export FLUENT_ARCH export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu:$LD_LIBRARY_PATH # The Journal file JOURNALFILE=test.journal # Total number of Processors # NPROCS=4 NTASKS=`echo $SLURM_TASKS_PER_NODE | cut -c1-2` NPROCS=`expr $SLURM_NNODES \* $NTASKS` fluent 3ddp -g -slurm -t4 -mpi=intel -path/opt/ansys_lic/v222/fluent -ssh -i $JOURNALFILE > fluent-out.log But still it gives the same error. Can you please let me know if I am in the correct way? |
September 14, 2022, 05:19 |
Brandon
Rep Power: 7 |
What you have above is probably also fine and just a syntax difference, but I would write it as: export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib/x86_64-linux-gnu echo $LD_LIBRARY_PATH The echo just to make sure your bash file even reaches this point. |
Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 13:43 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Prism Layer - Core Mesh Boundary Issue | InfernoxCJC | STAR-CCM+ | 7 | November 21, 2017 15:46 |
foamToTecplot360 issue with multiregion solvers | manuc | OpenFOAM Post-Processing | 2 | November 21, 2016 13:51 |
CFX parallel multi-node jobs fail w/ SLURM on Ubuntu 10.04 | danieru | CFX | 0 | February 17, 2012 06:20 |
