October 6, 2022, 15:42 |
Sectional Lift & Drag
Pierce
Rep Power: 6 |
I have a resolved wing on Fluent and want to extract sectional drag at given locations. I tried to do this by creating slices on my wing then performing a surface integral summation of a custom field function that for pressure drag would read X_face_area*Cos(AoA) + Z_face_area*Sin(AoA)*P_static. And to verify this will integrate to pressure drag if I am doing so for the whole aircraft, so there's no issue with this setup. However if I do it for a 2D wing section, I then have the issue where the face areas are not 2D, they're for the entire cells where the desired section cuts the surface grid and so I have a drag value that is acting over a given area and then how do you calculate that area.... Any suggestions? |
Sectional lift and drag coefficients | duybk2501 | FLUENT | 2 | August 3, 2022 08:24 |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 06:04 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 04:47 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
Sectional Drag and lift coefficient? | eRzBeNgEl | OpenFOAM | 7 | November 27, 2013 21:26 |
