Problem in rising outlet water temperature in PCM based System |
October 22, 2022, 18:30 |
Hello, I hope you are doing well, I have a question and I would be grateful if you could guide me I am simulating the below system,
System Double tube heat exchanger ************************************************** ************ Inlet domain is water::::::: Boundary condition::::: Tinlet=30 C Inlet= mass flow inlet=0.02 kg/s Outlet= Outflow ************************************************** ******** Outer domain is PCM::::: Boundary condition:::: Outer Wall under the influence of Irradiation 900 W/m^2 melting temperature=54 C ************************************************** **************** The initial temperature of system=30 C ************************************************* But I have a problem, The outlet water temperature does not change. I changed the length, PCM volume, and shape of the water domain( U shape and ...), It still hasn't changed. Please help me, thanks Thank you in advance for your time |
outlet temperature, pcm, phase change material |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) | dillon | Fluent UDF and Scheme Programming | 3 | March 25, 2018 11:06 |
CFX CHT increased mass flow rate for water matters little for outlet air temperature | dingsheng1206 | CFX | 7 | December 4, 2013 20:04 |
flow controled by outlet temperature | soonic | OpenFOAM Running, Solving & CFD | 0 | January 30, 2012 09:07 |
water temperature in heated container | ali | Main CFD Forum | 3 | July 23, 2007 11:54 |
