November 16, 2022, 07:53 |
Fluent interior zones to CFD-Post
Rep Power: 6 |
I'm doing a simple simulation of a pipe air flow in Ansys Workbench. The pipe has multiple inlets and one outlet and is surrounded by an enclosure. Because I want to analyze the flow for every pipe inlet I divided the whole domain in 2 parts in a way that it is intersected at the inlets to generate inlet surfaces. I then used the Share topology function to make the mesh conformal.
Fluent simulation went fine, but now I have a problem that the Interior surfaces that I defined using named selections in Meshing did not get exported to CFD-Post. Does anyone know how to get them exported. |
cfd-post, share topology |
Mutiple planes in cfd post ansys fluent | Aljelawy | Main CFD Forum | 0 | September 27, 2021 15:57 |
plot intermittency factor of a fluent solution in CFD post | alinik | FLUENT | 0 | October 12, 2017 18:12 |
CFD post & FLUENT | mariam.sara | FLUENT | 2 | September 14, 2015 04:43 |
Separate Convective and Radiative heat transfer in CFD post using fluent as a solver | Lemanes | FLUENT | 1 | July 6, 2015 10:31 |
fluent & cfd post | maziar | ANSYS | 0 | May 17, 2015 16:44 |
