December 8, 2022, 17:41 |
Fluid flow with inlet mass flow-outflow
MANU P ANAND
Rep Power: 11 |
I am having a flow consider a pipe flow, in which 9 bar gas is flowing, I don't know the outlet condition. I have simulated with by simulating by making 2D axisymmetric geometry as shown in figure? How to specify both pressure and mass flow at the inlet. I have specified the pressure of the fluid by specifying constant density. Because I don't know the outflow parameters I specified it as out flow at the outlet. How can I specify both pressure and mass flow?
December 8, 2022, 18:27 |
Lorenzo Galieti
Rep Power: 12 |
You can't specify both mass flow and pressure in one place. It is not physical.
In your case I would specify mass flow at the outlet and pressure at the inlet. |
December 9, 2022, 02:33 |
MANU P ANAND
Rep Power: 11 |
thank you your input was valuable, I was also thinking like that.
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 14:39 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
