Variable inlet temperature in Fluent
Old   January 20, 2023, 09:11
Default Variable inlet temperature in Fluent
Yogesh
yogesh03y is on a distinguished road
Hello all,
Is it possible to define a non-constant fluid inlet temperature in Fluent? I'm running a transient simulation.
My inlet temperature depends on the temperature of a cell zone and I know what the inlet temperature should be at different temperatures of that cell zone. I need Fluent to interpolate the inlet temperature between the ranges and not change abruptly (which I could even do manually).
For example,
At 650°C of cell zone, inlet temperature = 100°C,
At 600°C of cell zone, inlet temperature = 80°C,
At 500!C of cell zone, inlet temperature = 55°C,
...and so on.
Thank you!
yogesh03y is offline   Reply With Quote
expression, fluent - udf, inlet temperature, interpolation
Question about Solidification/melting model in Fluent yogesh03y FLUENT 0 December 17, 2022 15:15
Unhandled variable DPM-dist mahesh248f1 FLUENT 4 July 15, 2021 10:50
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit RPjack ANSYS Meshing & Geometry 1 June 20, 2019 07:11
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
