January 30, 2023, 09:18 |
Problem in parallel processing
Stark48
Rep Power: 3 |
Hello everyone!
I am facing a problem with parallel processing in Ansys Fluent. As usual I had set all my cores for solving at the start of the fluent but after hitting Calculate I can see only 1 core is being used. I am working on highly transient case and thus require all my cores. I went back to workbench and clicked Edit in Setup. The settings showed Serial processing as opposed to Parallel processing that I had initially set. I request your help in solving this problem. |
parallel calculation, parallel computing, parallel processing |
Problem in parallel processing [Process affinity not being set] | Roh | FLUENT | 4 | October 26, 2023 03:42 |
Temperature Problem in Parallel Processing | pdp.aero | SU2 | 9 | July 27, 2014 22:11 |
problem with parallel processing | keng | FLUENT | 4 | June 14, 2013 23:34 |
problem parallel processing (meshSearch, openMPI) | FabienF | OpenFOAM | 0 | September 10, 2012 04:23 |
About parallel processing in Linux | tuks | CFX | 10 | August 8, 2005 08:22 |
