Fluent meshing Error: arg(3rd) out of range in substring Error Object: 6 |
February 2, 2023, 05:51 |
Rep Power: 3 |
Hi, I'm using fluent meshing to create a mesh for a wind turbine. I added a local sizing to the turbine as well as to the floor. The problem comes when I try to run the Surface Mesh, the program throws this error:
Error: arg(3rd) out of range in substring Error Object: 5 I couldnt find any information about it online. If someone here knows what does the error refer to would be appreciated. Thank you |
March 8, 2023, 03:27 |
WANG Houzhi
Rep Power: 3 |
Hi, this problem happens maybe because the file name of your geometry or some part's name is too long. I renamed the file/parts and the problem was solved.
Hope this will help you. |
[Fluent Meshing] Rotating a mesh generated with Fluent Meshing | tinucci | FLUENT | 2 | April 16, 2024 10:23 |
Fluent Meshing poly-hexcore meshes for CFX | siw | CFX | 2 | November 18, 2021 09:49 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Transfer named selections from SW to Fluent Meshing | the-sted | FLUENT | 0 | May 1, 2016 23:44 |
