Mechanical Engr.
Like Tree2Likes
  • 2 Post By Sorin
Old   December 23, 2012, 13:16
Default Mechanical Engr.
F.Z. Hamadah
fhd79 is on a distinguished road
Hi there,
I have a problem in running fluent as a batch mode using Matlab, I am using the following command !C:\Fluent.Inc\ntbin\ntx86\fluent 2ddp -hidden -i "./FNACA4412.jou"
But I always end up with an error massage of:
Error: read-data: invalid plot file format
Error Object: *eof*
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
However, if I open fluent and used; file/read-journal ... and selected the journal file it will work perfectly..!!!
Please help and advice.
Thanx
FH.
fhd79 is offline   Reply With Quote
Old   May 9, 2013, 17:13
Sorin Munteanu
Sorin is on a distinguished road
Hi F.H.
Did you try using Fluent in server mode?
Instead of starting Fluent from inside Matlab you can start it from outside Matlab (could be on a different machine) and then connect from Matlab. You can run the TUI commands from the connected Matlab one at a time.
See below an example (I presume you are using Fluent R14.5...)
1. Have the Fluent COM connector registered to Windows
cd C:\Fluent.Inc\fluent14.5.0\addons\corba\ntx86\
regsvr32 ComCoFluentUnit.dll
1. start Fluent in server mode with the following command:
C:\Fluent.Inc\ntbin\ntx86\fluent 2ddp -aas
Fluent will generate a server key (aaS_FluentId.txt) in the folder where you launched Fluent
2. start Matlab and execute the following commands to connect to Fluent's TUI interpreter using aaS_FluentId.txt
fluent = actxserver(‘ANSYS.CoFluentUnit.1′);
tui=fluent.getSchemeControllerInstance();
fid=fopen(‘aaS_FluentId.txt’,'r’)
fluentkey=fscanf(fid,’%s’)
fclose(fid)
fluent.ConnectToServer (fluentkey)
3. run the commands in the batch file from Matlab, mixed with your Matlab commands. See below some examples
tuiCommand="report summary"
tuiOutput=tui.DoMenuCommandToString(tuiCommand);
rpVarName='pressure/relax'
rpVarValue=tui.GetRpVar(rpVarName)
4. When you are done you can shutdown Fluent from Matlab:
fluent.Terminate()
You can find all commands in the ANSYS Fluent aaS documentation. For a small example you can refer to my blog post at http://www.ansys-blog.com/tag/matlab/
Please let me know if you need more info.
Sorin
blackmask and vahid_ir like this.
Sorin is offline   Reply With Quote
Old   April 23, 2015, 18:06
Default Need Help
Iman Haji Gholami
iman h is on a distinguished road
Hi, thank you for your tips,
I have a problem in the first line.
I have an error :
Error using actxserver (line 91)
Server creation failed. Invalid ProgID 'ANSYS.CoFluentUnit.1'.
iman h is offline   Reply With Quote
Old   March 24, 2016, 10:47
s sur is on a distinguished road
I have an error :
I was able to make it work by omitting the ".1" after "ANSYS.CoFluentUnit", ie,
fluent = actxserver('ANSYS.CoFluentUnit')
worked for me. I was able to run FLUENT and pass TUI commands from MATLAB this way.
s sur is offline   Reply With Quote
Old   March 1, 2023, 18:42
ashish
ashishgupta is on a distinguished road
Originally Posted by Sorin View Post
Hi F.H.
fclose(fid)
fluent.Terminate()
Sorin
Hi Sir,
I am facing similar issue with Ansys MAxwell.
>> actxserver('Ansoft.ElectronicsDesktop');
Error using actxserver (line 93)
Server creation failed. Invalid ProgID 'Ansoft.ElectronicsDesktop'.
>> iMaxwell = actxserver ('AnsoftMaxwell.MaxwellScriptInterface');
Server creation failed. Invalid ProgID 'AnsoftMaxwell.MaxwellScriptInterface'.
Could you please help me out?
Thanks!!!
ashishgupta is offline   Reply With Quote
About 2 Way FSI (CFX+ANSYS Mechanical) shreyasr ANSYS 2 November 7, 2012 13:30
Incompressible flow: mechanical energy terms Pinaki Bhattacharya FLUENT 0 January 29, 2009 12:33
Help: Can a mechanical engineer be a programmer? JOHN Main CFD Forum 12 June 5, 2002 23:37
