Injection injection-0: LOST 2 out of 20 injection locations |
April 21, 2017, 07:18 |
Attaullah
Rep Power: 9 |
Need help;
I am running my simulation in which there are injections and particles are injected using DPM model. The simulation went well for the 2000 iterations but after that it did not inject the right number of particle parcels in the domain rather than it is showing the following msg in console arning: Injection injection-0: LOST 2 out of 20 injection locations, probably outside the domain. This will inject 10% LESS MASS. Plain orifice nozzle is single phase Warning: Injection injection-1: LOST 2 out of 20 injection locations, probably outside the domain. This will inject 10% LESS MASS. Plain orifice nozzle is single phase Warning: Injection injection-10: LOST 2 out of 20 injection locations, probably outside the domain. This will inject 10% LESS MASS. Plain orifice nozzle is single phase Warning: Injection injection-11: LOST 2 out of 20 injection locations, probably outside the domain. This will inject 10% LESS MASS. Plain orifice nozzle is single phase Warning: Injection injection-2: LOST 2 out of 20 injection locations, probably outside the domain. This will inject 10% LESS MASS. Plain orifice nozzle is single phase Warning: Injection injection-3: LOST 2 out of 20 injection locations, probably outside the domain Kindly help if somebody has any experience with that. Regards; Atta |
April 25, 2017, 07:48 |
Kal-El
Rep Power: 9 |
How is your injection defined? Surface or file?
April 25, 2017, 12:49 |
Injections
Attaullah
Rep Power: 9 |
April 26, 2017, 02:01 |
Kal-El
Rep Power: 9 |
I assume you are running fluent in parallel.
Check from 'Models - Discrete Phase - Parallel' which option are you using: 'Shared memory' or 'Message passing'? I once had very similar problem with one of these options. I don't remember which one. Maybe you can try both. |
April 28, 2017, 13:11 |
Dpm
Rep Power: 9 |
hallo everyone.
I want to inject nano particle in fluent.I have a reactangular geometry.But when I inject particle at my inlet the residual blow off and the solution divergence.Any help please?? |
May 5, 2017, 04:07 |
Kal-El
Rep Power: 9 |
I had something here, but it does not fit your problem.
For some reason, I can't delete this post. |
October 6, 2017, 00:00 |
nano particle injection
Anu
Rep Power: 9 |
hi,
i am facing some difficulties to inject nano particle in fluent. i know how set micro particle in fluent. what is difference between micro and nano particle set up in fluent .is there any one who can help me?. thanks in advance. |
October 6, 2017, 00:04 |
Kal-El
Rep Power: 9 |
October 6, 2017, 00:14 |
#9 |
Anu
Rep Power: 9 |
when I inject 10676 the particle size 3e-09 and run the simulation .After simulation I got this type of result number tracked = 1, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0.but the boundary condition was trapped.is there any other addition setting for Nano particle injection. is gravity is consider for Nano particle?
thanks for your cooperation. |
October 6, 2017, 00:34 |
#10 | |
Kal-El
Rep Power: 9 |
https://www.sharcnet.ca/Software/Ans...te_inject.html |
October 6, 2017, 00:44 |
#11 |
Anu
Rep Power: 9 |
From injection list I see it 627
October 6, 2017, 01:03 |
#12 |
Kal-El
Rep Power: 9 |
how is your injection defined?
October 7, 2017, 20:30 |
#13 |
Anu
Rep Power: 9 |
injection defined as a surface. can you please help me what is the additional set up is required when the particle will change from micro particle to Nano particle? i think if I get it then I can solve the problem.
thanks in advance for your help. |
October 9, 2017, 20:12 |
NaNo Particle injection
#14 |
Anu
Rep Power: 9 |
is gravity is consider for Nano particle case ?
can any one help me ? thanks in advance... |
May 16, 2020, 09:32 |
bothering for same problem
#15 | |
i faced the same problem(lost injections locations) which you met before. i use plain orifice model too.Could you please tell me how to solve it? In fact, i checked the ideal atomizer position in Design Model and Solidworks, no error shown for that. Thanks for your help. |
November 21, 2022, 03:19 |
DPM injection resulting in an error
#16 |
MAHRUKH
Copied from Ansys support website:
When setting up an injection and using the “List” option (say, to verify the number of injection points), this error for “lost particles” can show up if: 1. One or more of the injection point co-ordinates are lying outside the meshed regions 2. Case file is not yet initialized, or the data file is not yet loaded Last edited by Mahnoor; November 21, 2022 at 03:23. Reason: title modified |
March 2, 2023, 10:30 |
Dpm problem
#17 |
anonymous
Rep Power: 3 |
Injection injection-0: 20 particles lost outside the domain while spanning over partitions.
number tracked = 0 |
March 2, 2023, 10:31 |
Data quantities file
#18 |
anonymous
Rep Power: 3 |
i am doing but even after initialization its not working
UDF for particle injection using file | shahjehan | Fluent UDF and Scheme Programming | 2 | June 28, 2020 10:44 |
Diesel injection problem | Jurek | FLUENT | 2 | June 16, 2017 06:05 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
jou file command for the injection! | asal | FLUENT | 0 | June 4, 2013 04:15 |
using injection file and parallel process | Cindy Jones | FLUENT | 0 | January 23, 2003 12:40 |
