some questions about multispecies case ( fluent ) |
March 6, 2023, 12:55 |
mohammed abouras
Rep Power: 8 |
Hello dears,
I work with air dispersion case ( turbulent and species ) , my domain dimensions ( 220m * 140m * 90 ). the gases release in domain by vertical flow rate 27 kg/s and the velocity inlet 3 m/s (wind speed). but I didn't get the true plume behavior. my boundary conditions ( wind (velocity inlet ) , symmetry , wall , 2 stacks (mass flow inlet) , outlet (pressure outlet)) what should I do to get the results ? and get small residuals ? and what should I do to avoid reversed flow ? regards |
March 11, 2023, 12:40 |
mohammed abouras
Rep Power: 8 |
up .............
March 11, 2023, 15:06 |
Lorenzo Galieti
Rep Power: 12 |
can you post some pictures ? I absolutely got nothing from your description. I didn't even understand what you are trying to simulate
March 14, 2023, 13:49 |
#4 | |
mohammed abouras
Rep Power: 8 |
and I am trying to ensure that the plume distribute far from the buildings. |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
[Commercial meshers] Problems converting a Fluent case file | McFly | OpenFOAM Meshing & Mesh Conversion | 12 | July 21, 2019 21:02 |
General questions about how to mesh and build up my case | ThunderstruckGER | OpenFOAM | 5 | September 23, 2018 18:33 |
Can't run a case in HelyxOS with an imported mesh from Fluent | HHOS | OpenFOAM Running, Solving & CFD | 0 | July 2, 2013 06:25 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
