How to calculate penetration depth of a rigid body impinging in water? |
February 10, 2023, 04:07 |
Deepankar
Rep Power: 3 |
I am working on Numerical Analysis of rigid body impinging in water using Ansys Fluent in which I have to calculate penetration depth of that body in the water. I am unable to do that kindly help me regarding that. Thanks & Regards! |
February 10, 2023, 10:54 |
#2 | |
Kareem
Rep Power: 3 |
You can plot a report definition for the minimum Z value of body. This will create a plot of the bottom edge of the body over time. If you know the level of the water then you can calculate how far the body penetrates. I would recommend drafting your domain with the water level at 0. Then, from you plot, the minimum value it achieves will be the penetration depth.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
February 11, 2023, 02:35 |
#3 | |
Deepankar
Rep Power: 3 |
Can you please tell me from scratch or if possible please make a video on this? |
February 17, 2023, 10:09 |
#4 | |
Kareem
Rep Power: 3 |
Could you provide some images of your domain as well as the boundary conditions such as the size and speed of the sphere?
March 4, 2023, 02:13 |
#5 | |
Deepankar
Rep Power: 3 |
I used a dynamic mesh where I took only The body as the component zone and considered it as a rigid body only, mapped it with the mass of the object 19kg and took One degree of translation, and put the "y" value as 1. And did the hybrid initialization and patched it. I have taken two phases 1st is air and second is water. |
March 4, 2023, 02:17 |
#6 | |
Deepankar
Rep Power: 3 |
March 6, 2023, 10:22 |
Alan
Rep Power: 4 |
Are you using VOF? what are the boundary conditions on the moving object?
March 9, 2023, 03:43 |
#8 | |
Deepankar
Rep Power: 3 |
I have taken the body as a component zone and the domain as the background zone. All the walls of the domain I took as walls-background except the upper wall. For the upper face wall, I have taken the "specified pressure zone," which I gave as pressure inlet (Atmospheric pressure), as you can see in the screenshots. Last edited by Deepankar; March 9, 2023 at 04:08. Reason: I have to add Screenshots also |
March 9, 2023, 04:07 |
#9 |
Deepankar
Rep Power: 3 |
Yes, I am using VOF. And I am attaching screenshots of all the steps I took in the setup part numbered in sequence. Kindly look at that.
I have taken the body as a component zone and the domain as the background zone. All the walls of the domain I took as walls-background except the upper wall. For the upper face wall, I have taken the "specified pressure zone," which I gave as pressure inlet (Atmospheric pressure), as you can see in the screenshots. |
#ansys#fluent |
interDyMFoam - One rigid body, multiple boundaries | mattkram | OpenFOAM Running, Solving & CFD | 1 | March 29, 2021 08:36 |
Rigid body motion on transient fluent mrf | ghost82 | EnSight | 4 | September 6, 2014 11:24 |
Oscillation airfoil in infinite water depth | ldb83 | FLUENT | 14 | June 4, 2013 08:03 |
Free water jet impinging hot solid surface, including boiling | hamdy | Fluent UDF and Scheme Programming | 5 | August 19, 2012 19:52 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
