Is there an empirical formula for the wall shear of fully developed turbulence? |
March 26, 2023, 22:20 |
Rep Power: 4 |
Hi, everyone
I am using Fluent to obtain a profile of fully developed flow between two flat plates to reproduct a paper. According to the calculations, the wall shear stress is about 0.012pa, but in the paper the wall stress for a smooth channel is about 0.016pa. Since some parameters are not given in the paper, I would like to know if my calculation is correct or if there is some way such as an empirical formula to verify if my calculation is correct? The Reynolds number based on the hydraulic diameter (0.2m) is 20,000 and the channel size is 0.125mX0.5mX5m. The boundary conditions and the physical parameters of the working fluid (320K) are shown in the figure. p.png bc.png Thanks ! I exported the data on the variation of flow velocity with height on the outlet median. If I use this data to calculate it, it seems to give the right answer, so which data should I trust? (title "dX-Velocity/dz") (labels "Position" "dX-Velocity/dz") ((xy/key/label "line-6") 0.125 -825.673 0.1247 -815.572 0.12437 -763.692 0.124007 -644.875 0.123608 -488.059 0.123168 -349.908 0.122685 -252.343 Last edited by CarbonO2; March 27, 2023 at 03:08. |
Periodically fully developed (laminar and turbulent) flow and heat transfer within a | Abbas J | FLUENT | 0 | September 21, 2020 03:51 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Wall Shear in User Fortran | Allan | CFX | 0 | March 26, 2008 05:29 |
What is the detail definition of wall shear stress | zjm | FLUENT | 0 | January 2, 2002 07:43 |
