Problem with Periodic Boundary Conditions during Parametric Study
Old   April 11, 2023, 13:48
Default Problem with Periodic Boundary Conditions during Parametric Study
Gary Farrell
gfarrell is on a distinguished road
Hi everyone, this is my first time posting to this forum (or any forum), so hopefully my post follows the guidelines okay. I cannot find any other thread on here discussing this issue.
Setup: I am simulating flow around a 3D airfoil cascade. I am modelling only one airfoil and applying translational periodic boundary conditions to the two sides of the air domain (See plan view of the air domain, Surface 1 & 2). I want to study the effect of airfoil angle of attack.
I made my original CAD in SOLIDWORKS and I have ‘attached’ this CAD model to Design Modeler. I used ANSYS Meshing to create my mesh (no-matching controls) and loaded into Fluent.
For simplicity, I created a non-conformal periodic translational boundary condition in Fluent by first creating a mesh interface between Surface 1 & 2. I have no issue setting up/running this initial case manually.
I create my various design points in Workbench by varying the angle of attack parameter in each design point. This will alter the airfoil angle of attack, and the angle of the middle section of the domain. Here are the two problems…
Problem 1: I have read that the “Automatic Compute Offset” function sometimes causes issues when setting up periodic conditions, and that it’s best to input offset manually. When creating the periodic boundaries, I disable “Automatic Compute Offset” and input the offset manually, as the offset is the same for all angles of attack. However, when I close the interface setup window and re-open it, “Automatic Compute Offset” is enabled again…
Problem 2: This is causing issues in the parametric study. I cannot consistently update the design points, as for some design points Fluent throwing an error like “Automatic Offset Computation Failed” and “Cannot Apply Some Mesh Operations”. For some design points, there is no issue (the new mesh is loaded perfect into Fluent and the calculation is carried out). However, in some cases, the “Automatic Compute Offset” option cannot compute the offset between the two surfaces I want to make periodic. This seems to happen randomly at some design points…
Does anyone know how to solve these issues? Is there any way to ensure that “Automatic Compute Offset” stays disabled? And if not, why does the “Automatic Compute Offset” fail at some design points and not others?
I’ve spent a week trying to solve this, yet I can’t. My gut feeling is that there’s some issue with Workbench loading the new meshes properly into Fluent.
I would greatly appreciate anyone’s help on this issue… thank you very much!
gfarrell is offline   Reply With Quote
Old   April 13, 2023, 10:32
Default Automatic Compute Offset for Periodic Boundary Conditions
me12p1006 is on a distinguished road
Hi Gearoid,
I am not sure whether you looked in to this thread. May be, if not, look in to it. It shows some conclusion for auto-compute-offset issue.
https://forum.ansys.com/forums/topic...ies-in-fluent/
me12p1006 is offline   Reply With Quote
Old   April 13, 2023, 10:42
Gary Farrell
Originally Posted by me12p1006 View Post
Hi Gearoid,
Hi! Thank you for your response! I did come across that thread, however, they did not explain why you cannot permanently disable "Auto Compute Offset"... it seems to re-enable itself straight after you disable it...
Old   April 29, 2023, 12:04
Default Did u get the solution?
Vaibhav Hiwale
vaibhavhiwale is on a distinguished road
I'm also facing the same
Problem. Pls let me know if you able to solve that problem.
vaibhavhiwale is offline   Reply With Quote
fluent - parallel, interface bc, offset, periodic bc
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Problem with periodic boundary conditions jm_ngs FLUENT 7 April 27, 2012 02:32
Problem with using periodic boundary conditions Sun FLUENT 0 January 14, 2011 09:47
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
