Workbench Fluent save every DP in Legacy format
Old   April 20, 2023, 03:44
Default Workbench Fluent save every DP in Legacy format
CFDger is on a distinguished road
I am running multiple Design Points within the Workbench with Fluent. I want each Design Point to be saved in Legacy format (in order to get access to all variables in CFD-Post, which I believe I don't get writing in CFF format, please correct me if I'm wrong).
Setting the Setup in the Fluent Block within the Workbench up via: File -> Preferences -> Default Format for I/O -> Legacy
.. I receive this error:
"C:\Users\myname.
A subdirectory or file with the name "myname\.fluentconf" already exists.
The following error occurred: myname\.fluentconf."
i already deleted that file and the Ansys folder in the Appdata directory...
Any help on this is highly appreaciated!
CFDger is offline   Reply With Quote
Old   April 20, 2023, 04:56
Update: This way (even though the error appears) I can actually save the file of that specific (current) design point in the legacy format.
When I update other Design Points they are then unfortunately saved in CFF format again. As a restult in CFD-Post I can't access variables such as the mach number etc...
design point, fluent, legacy, workbench
Sutile and Tricky : Drive Fluent UDF parameters directly from workbench amscosta Fluent UDF and Scheme Programming 4 July 21, 2020 16:50
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
[ANSYS Meshing] polyhedral mesh which is generated directly in Workbench Poly Meshing for Fluent teguhtf ANSYS Meshing & Geometry 0 January 24, 2019 22:04
implementing UDF for fluent in workbench for running multiple simulations faizan_habib7 Fluent UDF and Scheme Programming 0 March 18, 2016 22:29
FLUENT WORKBENCH vs FLUENT rcerdeira FLUENT 0 March 17, 2010 05:05
