April 26, 2023, 11:49 |
Error when creating an enclosure
Vasco Godinho
After I generated my geometry on DesignModeler, I created an enclosure. However I got this error and warning:
Error: Boolean operation failed Context: Geometry Engine, while generating Feature Enclosure1 Warning: At least one of the imported/attached/converted bodies could not be validated. It is possible that subsequent modeling operations will fail. Additional information: The following could not be validated: Component7, Component17, Component20 Context: Feature Enclosure1 Warning: Invalid enclosure body(s), inputs likely have faults Context: Enclosure Feature Enclosure1 Any suggestions or tips on how to overcome this? |
May 10, 2023, 00:27 |
Vignesh Rajendiran
Rep Power: 9 |
You have probably imported the geometry that was generated in some other software.
In order to generate an enclosure and extract fluid volume, you have to first ensure that your geometry is watertight. Only a watertight geometry can be used to extract fluid volume. Every CFD engineer will first spend time to clean up the geometry and ensure that it is watertight before moving on fluid volume extraction. And try using Spaceclaim instead of Design Modeler to clean up the geometry. It is more user friendly. |
Creating Enclosure | Onur Koç | CFX | 2 | May 25, 2020 21:48 |
[DesignModeler] Non-manifold body during creating enclosure | Gnak | ANSYS Meshing & Geometry | 1 | January 26, 2018 17:54 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[DesignModeler] Help Creating an enclosure | n.jithin.1991 | ANSYS Meshing & Geometry | 0 | April 26, 2013 02:25 |
Creating large enclosure containing many persons | Michael | CFX | 0 | January 21, 2009 05:42 |
