Ahmed Shaaban
Rep Power: 0 ![]() |
I'm fairly new to Ansys Fluent and I'm trying to simulate the flow around a 3D cylinder at Re = 300. I'm using transient, pressure-based solver All models are turned off except viscous model I'm using laminar model . My domain dimensions are 20m from the inlet to the cylinder axis, 30m from the outlet to the cylinder axis, 20m from the bottom and top wall and 12m on the z direction. the cylinder has a diameter of 1m and a spanwise length of 12m. My boundary conditions are velocity inlet at the inlet v = 0.00438 m/s, pressure-outlet at the outlet, no-slip boundary condition is imposed on the cylinder, for the top and bottom walls I specified a shear condition with shear stress at all component equal to 0. For the walls on spanwise (z-axis) direction I tried creatin a periodic boundary condition but I'm not sure if I did it right. My Cd values seems to remain the same whether I create a periodic boundary condition or not and the average Cd is very high giving me a value of about 11. Kindly please help me resolve this. |
ansys |
Flow around 3D cylinder at Re = 300 | Ahmed8 | FLUENT | 0 | May 22, 2023 03:14 |
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 14:44 |
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low | Scabbard | Main CFD Forum | 21 | June 19, 2018 13:58 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
