Creating Stirred Tank Reactor Geometry With Magnetic Rod Stirrer On Base |
June 7, 2023, 06:33 |
sr786
Rep Power: 3 |
I am attempting to create a geometry with a magnetic rod stirrer (cylindrical) lying on the base of the reactor. I have used a boolean operation to subtract the rod from the reactor (at typical approach when modelling a stirred tank reactor) but I notice the cell skewness is very poor (0.99) meaning that I cannot run this mesh in ANSYS FLUENT as the simulation will blow up (even if I use PISO with skewness correction it doesn't work).
Does anyone have any suggestions on how to put the rod stirrer on the base of the reactor without the simulation blowing up (i.e., how to lower skewness of mesh) Geometry.PNG Skewness.jpg |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Gambit Meshing of stirred mixing tank | shadyenany | FLUENT | 4 | September 15, 2011 12:13 |
