June 9, 2023, 07:19 |
DPM simulation
Italy
Rep Power: 4 |
Hy everyone, i have simulated on fluent a dpm injection of water inside an air eductor/ejector. The solution has converged and everything is ok, but anyone knows how to verify if the solution is correct? I mean, in terms of physical parameters/contours/plots.
Because i have made a literature research and it's very difficult to find studies related to this case. Thanks in advance. Alessandro |
DPM Transient Simulation | Saxon HUI | Fluent UDF and Scheme Programming | 0 | June 16, 2022 08:24 |
Problem on succesive simulation runs and dpm file naming | fatihgulec | Fluent UDF and Scheme Programming | 4 | April 5, 2022 08:08 |
CFG file Set Up | Nicola_Fontana | SU2 | 5 | November 16, 2021 12:48 |
Can I do simulation hypersonic model with DPM in 2d ? Please help me | diwakarreddy | FLUENT | 0 | May 6, 2021 12:38 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 05:28 |
