Translation materials and bc
Old   June 9, 2023, 03:16
Default Translation materials and bc
pavlenty is on a distinguished road
Hi!
Is a posibility in Fluent to translate materials and bc etc. from one case file to another? And not to define material properties again? Like ccl.-file in CFX.
pavlenty is offline   Reply With Quote
Old   June 9, 2023, 09:47
Moritz Kuhn
MKuhn is on a distinguished road
Regarding the materials. Create an empty document called mymaterials.scm or somthing else. Then go to "Create/Edit Materials" and choose this file under "User-Defined Database". Then click "Copy Materials from Case..." save and Close. Now you can use your mymaterials.scm in every other case file.
Regarding the BC, if you just change the mesh, FILE --> Read Mesh and choose just Replace Mesh. You can also write a Journal File durign your BC set up and read it again in a new case.
May be there are more options.
MKuhn is offline   Reply With Quote
Old   June 9, 2023, 10:03
Thank you very much.
