July 19, 2023, 13:01 |
Battery modeling with mixture model enabled
Iason
Rep Power: 3 |
Hello everyone,
I am trying to simulate the cooling of a battery by means of a fluid that undergoes a phase change from liquid to vapour. For this reason, I want to use the MSMS model for the battery and the mixture model for the two-phase flow and phase change. I notice that in the version I am running, 2022R1 these two models are not compatible and as soon as I turn on the multiphase model the battery is turned off. On the contrary, if I run it in 2020R1 this does not happen and the modeling can be done normally. Since I now have access to the latest version, 2022R1, I want to ask if there is a way to be able to use both of these models at the same time. Thank you in advance for your assistance |
battery modelling, mixture model, msmd battery, multiphase model |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
Difference between Mixture & Eulerian multiphase ? | Shankar | FLUENT | 6 | October 7, 2015 08:45 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
mixture model, sand transport | rayolau | FLUENT | 0 | September 18, 2012 13:34 |
species transport model or mixture model?HELP | zhhjll | FLUENT | 3 | March 5, 2011 15:27 |
