How can i get properties using UDF
Old   July 26, 2023, 00:26
Default How can i get properties using UDF
HOJUN YU
hobing is on a distinguished road
Hello I am using the Fluent V19 to analysis the propeller.
The propeller is analyzed in unsteady, and at each time step, a udf is created and used to obtain the coordinates of the various faces of the propeller surface, normal vector (x,y,z), force (x,y,z), static pressure, and area there is.
But there are some problems. Does anyone know how to achieve the above using udf? can someone help me?
..\..\src\udf.c(9): error C2040: 'x': 'real'
..\..\src\udf.c(22): error C2065: 'THREAD_WALL':
..\..\src\udf.c(27): error C2065: 'farea':
..\..\src\udf.c(27): error C2109:
..\..\src\udf.c(28): error C2223: '->storage'
..\..\src\udf.c(32): warning C4477: 'fprintf' :
Below is my udf code.
domain = Get_Domain(3); where 3 is the boundary condition ID of the propeller.
#include "udf.h"
DEFINE_EXECUTE_AT_END(store_wall_info)
    Domain *domain;
    Thread *t;
    face_t f;
    real x[ND_ND];
    real x, y, z, area, pressure;
    real nx, ny, nz, fx, fy, fz;
    FILE *file;
    int time_step;
    time_step = N_TIME;
    file = fopen("wall_info.txt", "a");
    thread_loop_c(t, domain)
        if (THREAD_TYPE(t) == THREAD_WALL)
            begin_f_loop(f, t)
                F_CENTROID(x, f, t);
                F_AREA(farea, f, t);
                F_P(pressure, f, t);
                F_NORMAL(nx, ny, nz, f, t);
                fprintf(file, "%e, %e, %e, %e, %e, %e, %e, %e, %e\n", x, y, z, area, pressure, nx, ny, nz, fx, fy, fz);
            end_f_loop(f, t)
    fclose(file);
hobing is offline   Reply With Quote
Old   July 27, 2023, 01:43
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you are talking about thread not domain.
domain is 1 for single phase flow
t=Lookup_Thread(domain, 3);
so you dont need this loop
compile code
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 27, 2023, 02:33
HOJUN YU
Thank you!
thank you The code is modified and in use.
But I have one question for you.
I can output the cell coordinates of the WALL corresponding to ID 19. I want to know the cell's NORMAL VECTOR and FORCE X, Y, Z.
FORCE = P * A is defined as
It can be defined as FORCE X = P * A[0]. If defined here, the output will be 0.
How should I define it?
#include "udf.h"
FILE *fout;
DEFINE_ADJUST(print_f_centroids, domain)
    real FC[3];
    /* real es[3]; */
    /* real force_x, force_y, force_z; */
    face_t f;
    /* real NV_VEC(A); */
    int ID = 19;
    Thread *thread = Lookup_Thread(domain, ID);
    fout=fopen("faces.out", "w");
    begin_f_loop(f, thread)
        F_CENTROID(FC, f, thread);
        fprintf(fout, "xc = %f yc = %f zc = %f, fx = %f, fx = %f, fx = %f", FC[0], FC[1], FC[2]);
    end_f_loop(f,thread)
    fclose(fout);
Obtaining fluid properties using UDF UchihaMadara Fluent UDF and Scheme Programming 5 May 24, 2021 21:47
UDF phase properties separately U1990 FLUENT 3 April 13, 2021 03:37
Checking UDF material properties salumi FLUENT 0 December 2, 2016 05:57
How to show the properties in the specific zone ID using UDF (Define_adjust) sagga18 Fluent UDF and Scheme Programming 2 December 12, 2009 16:01
How to find Properties of Fluid at specific location, using UDF? pmghadge FLUENT 0 December 8, 2009 13:53
