Printing at each iteration using udf
Old   August 2, 2023, 10:32
Default Printing at each iteration using udf
Shaik Raheem
Shaik Raheem is on a distinguished road
Hi all,
I want to print the variables(pressure, temp, etc.) in fluent at each iteration using udf. what is the Macro used for it?
help me..
Shaik Raheem is offline   Reply With Quote
Old   August 4, 2023, 04:41
Moritz Kuhn
MKuhn is on a distinguished road
Why do you want to you use a marco for that? There are serveral possibilities in the GUI to do this. Your can print the values to the screen and/or store in a file.
MKuhn is offline   Reply With Quote
Old   August 4, 2023, 06:30
Shaik Raheem
Thank you for the reply
Actually i am dealing with transient flow. I am using udf for adding source terms to mass and energy equations. In each time step, after several iterations solution will be converged. I am getting the variables printed in a text file after every time step. But i wanted to see at every iteration. I came to know that we can use DEFINE_ADJUST macro.
Old   August 4, 2023, 08:00
Moritz Kuhn
I think, that you can change in the report definition the output intervall from flowtime to iteration.
Sorry, I can't give you a quick solution to do this in a UDF.
Old   August 4, 2023, 08:06
Shaik Raheem
OK.... I don't know that we can print in the report for every iteration. Thank you .. i did with udf today.. i will look at report definition also.
Have a good day
Old   August 4, 2023, 08:17
Shaik Raheem
could you please tell me how to do that in report definition?
Old   August 4, 2023, 08:19
Moritz Kuhn
I'm not on my PC with FLUENT. Sorry you have to check the user guide.
Old   August 4, 2023, 08:21
Shaik Raheem
Ok. I will check
Kernel for new CPUs Simbelmynė Hardware 22 January 5, 2018 16:41
Boundary condition changing at every iteration : How to write a UDF ? Adrae ANSYS 0 August 10, 2016 10:11
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 07:26
udf - iteration number within one time step?! Mira FLUENT 1 January 23, 2008 03:16
printing values from udf!!! Shekhar FLUENT 2 January 13, 2004 11:49
