Simulation Diverges after Pausing and Restarting
Old   August 12, 2023, 08:59
Default Simulation Diverges after Pausing and Restarting
nicola
yanqoue is on a distinguished road
I had a VOF2DPM case with adaptive mesh refinement. It was running smoothly. Then I realized that I should add one more variable for the outputs (which doesn't effect anything).
I did that and re-started the simulation by using the latest ".cas" and ".dat" files, because mesh is constantly changing so does the case file. But suddenly simulation started to diverge, courant number jumped by 2 times.
What is the problem?
If I didn't stop the simulation, everything would be fine.
But what could cause this issue? I didn't change anything, I just interrupted it.
yanqoue is offline   Reply With Quote
